C-1 Motor Mount - NCRS Discussion Boards
C-1 Motor Mount
  • Jerry C.
    • November 1, 1995
    • 741
    C-1 Motor Mount
    Can someone explain the differences in motor mounts from 55 to 60? The mount between the block and water pump. Thanks in advance.
  • Doug F.
    • November 1, 1983
    • 322
    Re: C-1 Motor Mount
    i think the early ones don't have clearance to change the front soft plug in the block, the later ones do
    • Wayne L.
      • September 30, 1981
      • 233
      Re: C-1 Motor Mount
      Jerry-
      The 55-58 mount is not cut out for the front soft plug. Not sure when the change was made, but later ones (59-60) are cut out for access to the right front soft plug. Wayne
