I recently flushed the cooling system on my 75 L48 coupe. I filled the overflow tank up quite high, and over the last month, it has settled a bit. In other words, some fluid "disappeared" while driving. I do not see any leaks, everything is tight, and the car runs at normal temp. I am assuming I overfilled the tank, and it has just purged itself while driving. Am I correct? I do not see any marks on the overlow tank indicating a low or hot level, how much antifreeze should be in the overflow? Thanks for any input.
Coolant overflow tank
Re: Coolant overflow tank
Lyle,
I had the same mix in the overflow tank, I think I had the tank too full and it burped some coolant out as the car ran. There is no molded mark on the overflow tank indicating a cold or hot level of fluid. Maybe I just overfilled it.- Top
When the water cools down again, water gets "sucked" back into the radiator.
So it may well be, that the excessive water was drained down the overflow hose of the overflow tank...
Just keep an eye on the system and don't let it run dray (say keep the level a couple of inches above the lower end of the "suction hose" inside the overflow tank). If the level remains there, don't worry!- Top
When you flush the system you will have air in the system. The overflow tank just replaced the air with antifreeze as it should. It should be OK now but if the oil level goes up and the coolant goes down their is a probem.Lyle
