Friend of mine has an '81 with 6700 original miles. After sitting for a year he finally took it out for a ride. Prior to this recent ride, everything worked correctly. Now the problem(s) are that the choke light stay on all the time, Tach gauge sits bottomed (approx) 1.5" below 0 rpm, the temp gauge sits/stays approx 125-130, fuel gauge sits pegged beyond full, he occasionally has an intermittent 'check engine light', and run has 'run on' after turning off. I know that a car sitting for long periods is not good, but all this stuff going bad, all of a sudden, just doesn't make much sense.
Before we pull gauges / panels, I remembered that the last time he had car out was for a show, where we were messing with the wire shielding in engine bay. I am wondering IF we might have hit/loosened some sort of bulk head connector, or some module, or?
My question(s):
David
My question(s):
- Is there, possibly, something in common with all of this?
- If YES, where would we find this connector? Location?
- If NO, I know center gauge console is susceptible to breaking 'ears' off panel. What do we need to know on removal/installation?
- Is there any documentation for removal, etc...?
David
