goofy block..... - NCRS Discussion Boards
goofy block.....
  • Bill W.
    • November 1, 1977
    • 402
    goofy block.....
    I bought a car that has a small block chevrolet engine with the following numbers; cast# 3959512, date A230, stamped CEOA 38252. Does anyone recognize the casting number? I checked Covin's book but it is not listed. It was represented to be a 327, is it? Bill
  • Dan H.
    • July 31, 1977
    • 1365
    Re: goofy block.....
    Bill, it's a 'Chevrolet Engine' 'CE' that was a replacement short block etc. from Chevrolet Dealers. They used the 512 casting number. The other numbers are mfr sequence numbers. Archives have more details on decoding it.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Tom H.
      • December 1, 1993
      • 3440
      I believe that casting would be right for a 327.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Bill W.
        • November 1, 1977
        • 402
        Thanks guys. I wanted to confirm that I have a 327 in there, not a 283. Bill
        • Dan H.
          • July 31, 1977
          • 1365
          Bill, the date is probably for 1970, that's during the time the CE engines were available.
          Dan
          • Jim T.
            • March 1, 1993
            • 5351
            Dan
            Dan I believe you have posted the correct information in identifing CE0A. I have a CEOA 47538 but it is a 3970010 block with a casting date D260. I know my block is a 350. I have had it for 39 years this month and know when it was installed at the dealer.
              Bill-----
              It's definitely NOT a 283. The 3959512 block was a 4" bore block, so it could not be used for a 283. There's a possibility it could have been built into a 350 cid engine (with small journal crank), but it's very unlikely.
              • Chris W.
                • September 30, 1982
                • 49
                The '512 Block was a service replacement and was usually sold as a short block or fitted block back in the late '60s or early '70s. It was of a 327 configuration with the vent on the back by the distributor. This block is based on the '010 350 patterns but had the vent and was usually machined with small journal mains. It will have the numbers "010" behind the flywheel and in the timing chain area. It is a very good block to make a vintage race engine out of for a mid year as the main webs and cylinder walls are thicker then the earlier 327 blocks. These blocks can be easily machined for 4 bolt mains and large journal cranks.
                Number wise, this block is not usable for a "Numbers Matching" restored car.
                I hope this helps.
                Chris
