Late 59-67 script valve covers. - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    How can you tell the late 59-60 script valve covers from the 61-67 script valve covers?
    Thanks.
    Re: Late 59-67 script valve covers.
    58L-59 valve covers have attaching bolt holes 'staggered' to match the position of the the threaded inserts in the cylinder heads. 59L-67 covers are identical but with two exceptions:
    (1) All have attaching bolt holes straight across (top to bottom).
    (2) '66L-67 covers have the casting flaw (line of flash) through the 'O' in the Corvette script.
    • Greg L.
      • March 1, 2006
      • 2291
      Sorry Jack but I was referring to the stamped steel ones.
      It was my understanding that the staggered bolt pattern is as you say however Paragon lists three types of stamped steel script ones in their catalog.
      *1955 - early 1959
      *early 1959 - 1960
      *1961 - 1967
      They don't say what the difference is between the last two "versions".
      Any ideas?
      • Greg L.
        • March 1, 2006
        • 2291
        Does anyone have any thoughts on this or is Paragon wrong?
        • Jim L.
          • September 30, 1979
          • 1805
          *1955 - early 1959
          *early 1959 - 1960
          *1961 - 1967
          Any ideas?
          What their catalog actually says is '61 base 283 and '67 base 327 (or at least that's what my catalog says).
          The ends of the EARLY (late '59 - '60) covers are straight up and down. The ends of the LATE covers are slanted
          Jim
            '67 base engines used a one-year-only stamped steel valve cover.
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1464
              Good point, Jim.
              It is also good to note that the slant is greater (detectable) on the passenger cars, which, at a glance of an untrained eye, may appear to be the same.
              More on the "Uniqueness" that John pointed out.
              HaND
