1970 Rear Spring - NCRS Discussion Boards
1970 Rear Spring
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 1970 Rear Spring
    Sources:
    (1) For front coil springs, Noland Adams' Vol 2, lists the equivalent spec (free height) in his Specifications section at the rear of the book. I presume Noland's source was Chevy...
    (2) Unfortunately, there is no equivalent spec for the rear spring (free arch).
    (3) I went to a Denver local suspension shop (in business since 1922) and they looked up the free arch specs in their manuals which I believe were written by Eaton using the GM PN for the spring(s) as the table lookup input... So, I hand annotated my copy of Nolands' book with the rear spring free arch specs (10" for the 9-leaf and 6.25" for the 7-leaf).
    • Mark A.
      • June 4, 2009
      • 55
      Wow......
      This is great information guys!
      I need to take some meaurments on the 9 leaf spring I have.
      I am tied up with obligations this weekend so I hope to get to it early next week....
      I'll keep you posted.
      Thanks again.
      Mark
      • Mark A.
        • June 4, 2009
        • 55
        Just to let every know I did check the free arch of my new 9 leaf spring and it was 10 1/8
        I did get it installed last night and it did bring the car down a little over an inch (29.25) so I figure with a full tank and some wear and tear it should come down another inch which would be perfect.
        Thanks for all your help guys, I couldn't have done it with-out you......
        Mark
        • Roberto L.
          • January 1, 1998
          • 523
          Thanks, good information!!!!
