Plastic lower fan shroud extension - NCRS Discussion Boards
  • Craig D.
    • March 1, 2001
    • 98
    I would like to ID a shroud extension I had in my garage, dont even remember how I got it,but just discovered it in the corner. Black plastic like 1970s shroud material part # is 3956089, that number is molded in at the lower cutout at very bottom of the part.
    Any input appreciated. TIA, Craig
  • Tom L.
    • October 17, 2006
    • 1439
    Re: Plastic lower fan shroud extension
    Mine is missing so I checked my AIM. It is a for a '72 LS-5.
    Is it altered or is the notch correct, someone might know.
    If you are willing to part with it I may be interested, send me a PM if this is the case. Have fun!
    • Craig D.
      • March 1, 2001
      • 98
      Lynn,
      Thanks. The notch in the bottom is correct since I see injection flash around the edges from when it was molded. It was not cut.
