66 rear spring info - NCRS Discussion Boards
66 rear spring info
  • Bill H.
    • November 15, 2007
    • 54
    66 rear spring info
    I'm restoring a 66 bb car and the rear spring does not appear to be correct. It does have 9 leafs but no turnups at the ends.
    If I were to replace the spring, What would be the correct spring?
    I see the f 41 -7 leaf is being reproduced, will that be correct, and will I need to change other pieces to keep it correct.
    should I be looking for another 9 leaf? BB with HD rearend.
    Re: 66 rear spring info
    Bill -
    Big-blocks used the same 9-leaf spring as small-blocks, unless they had F-41 (which was only available with L-72). Eaton Detroit Spring has an excellent reproduction 9-leaf spring - just needs re-painting and Quanta liners. I believe they also have a 7-leaf if that's what you need.
    www.eatonsprings.com
