82 Corvette Brake Pedal pressure - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi Guys,
    Dave
    Re: 82 Corvette Brake Pedal pressure
    Dave -
    Sounds like a re-bleed is in order; those are symptoms of air in the lines.
    • David S.
      • August 9, 2009
      • 595
      Thank you John. Time to hit the garage.
      -Dave
      • William T.
        Infrequent User
        • April 1, 1985
        • 12
        I am curious- did you pressure or vacuum bleed? I'm doing brake work on two C3's. The vacuum bleed method is not giving me good results. I'm going to connect my pressure bleeder- I never had anthing but good results with that. Good luck!
        • David S.
          • August 9, 2009
          • 595
          At first I vacuum bleed the brakes with a little hand pump. But since I was not satisfied I then pressure bleed them with someone in the driver seat.
          PS - I pressure bleed the brakes last night, took out the car this morning and a world of difference.
          Dave
