61/62 Doors - NCRS Discussion Boards
61/62 Doors
  • Sandy G.
    • March 1, 1995
    • 10
    61/62 Doors
    I just bought a '61 project car. The doors do not have the holes for the cove trim. Are the 61 and 62 doors the same? If not, can the cove trim be mounted an a 62 door?
    Re: 61/62 Doors
    Sandy -
    The '61 and '62 doors are different - the surface where the bright cove trim attaches on a '61 is flat, and that same surface on '62 doors has a raised, pointed feature line; you can't install '61 cove trim on a '62 door.
    • Sandy G.
      • March 1, 1995
      • 10
      Re: 61/62 Doors
      John, thank you for the help. Sandy Gilman
      • Richard T.
        • February 1, 1979
        • 858
        Re: 61/62 Doors
        If your doors are original to the 61 the hole were probably filled by a prior owner. If so it should be a simple matter to locate the filled holes from inside of the door and open them up. Rich
        • Jim H.
          • April 1, 2002
          • 112
          Re: 61/62 Doors
          I have a 61 door in california. I am willing to sell it if you need it. It is just a core with no interior parts. Also, I will have some left over parts from my 62 project. Just thought I would pass it along. It is a passenger door. (just one since the other one is quite messed up. The other side is a outside shell only.
          • Christopher R.
            • March 31, 1975
            • 1599
            Re: 61/62 Doors
            58-61 and 62 doors are different. 62 doors generally sell for more than the others.
            • Jim H.
              • April 1, 2002
              • 112
              Re: 61/62 Doors
              I know 61 doors are longer than 59 doors (not sure about 60) since the door end caps are longer. That makes the 61 doors special.
              • Scott P.
                • April 30, 1992
                • 178
                Re: 61/62 Doors
                Sandy the doors are also very different on the inside panel as to the way the armrest or door pull bolts to the door. Scott
