C3 convertible lock pillar repair, with pics - NCRS Discussion Boards
  • Joseph H.
    • December 11, 2007
    • 159
    The upper corners of both of my E69 lock pillars (under the lock pillar weatherstrip) are broken, presumably from slamming shut the convertible top cover over the years. Although the vehicle does not go out in the rain what is the best method to repair these? There seems to be enough glass material there, so can I use epoxy or a bonding agent and clamp them into position until dry?
    I have searched through the archives without any luck............
    Joe
  • Rich P.
    • January 12, 2009
    • 1361
    Re: C3 convertible lock pillar repair, with pics
    Joe,
    this is very common both on C-2's as well as c-3's. The best way to fix it is to wedge a paint stick between the split areas and sand both sides, then make a paper funnel to apply the glue with and squeeze the glue into the crack, remove the paint stick and clamp them together. You can use any corvette glue or fiberglass 2 part epoxy.
    Rich
    • Joseph H.
      • December 11, 2007
      • 159
      Thanks for the info, I will give it a try over the fall/winter months. Just another item to add to the list.
      Joe
        • 3415
        Hi Joseph,
        When I looked at your pictures I wondered "what's hitting it hard enough to do that"? Does something need a little adjustment or just a more gentle hand in closing? I wouldn't want you to do the repair and then have the problem start over.
        • Rich P.
          • January 12, 2009
          • 1361
          Joe,
          Here's a picture of a paper funnel in action. I made this to glue on a pair of parking lamp panels for a 66 I'm restoring for a customer. The one you need to make will be smaller as you won't need that much glue for this repair.
          Rich
          • Wayne W.
            • April 30, 1982
            • 3605
            Hi Joseph,
            My guess is that the deck lid w/s is for the later model and has the end piece that is not required on the `69. Just a guess.
            • Joseph H.
              • December 11, 2007
              • 159
              Thanks again for the info. From what I can tell the W/S on this car is correct, the early style and has never been replaced. The 2nd version has a second piece to it, where the 1st version is one piece.
              The lid lines up fairly well when closed, so I think this problem is from 40 yrs. of someone slamming this lid closed, instead of gently closing it. I have only owned this vehicle for about 2yrs.
              The person who restored this vehicle only did half the job and some of that was not done very well. I am in the process of identifying and attempting to correct many more items.
              Joe
                Originally posted by Rich Pasqualone (49858)
                Joe,
                Rich
                That's EXACTLY the way St. Louis applied ALL the bonding adhesive; air-powered stand-up bond mixer/dispensers, roll-it-yourself paper cones, and scissors to snip off the end.
                  • April 30, 1984
                  • 158
                  Joe, a warm day or a heated space will help with epoxy setting up as it should.
