Stamp Pad Experts, please! - NCRS Discussion Boards
  • John C.
    • January 1, 2001
    • 171
    Please take a look at the attached photo of my engine stamp pad and gvie me some opinions on it's originality (or lack thereof).
    The entire block was rusty so I'm fully aware of the lack of broach marks. I am just wondering about the numbers, letters, etc.
    Thank you!
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Stamp Pad Experts, please!
    I'm no expert, by any means. That is a tough call. The last R looks like it doesn't match the first one, but I've seen stranger. Do you know any history of this block ?? How long have you had it ? Looks like a neat block to be a 365 with AC. Pretty good span between assembly date of the block and VIN.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • John C.
      • January 1, 2001
      • 171
      I acquired the block when I bought the car. It is a 365HP with air coupe, it has the correct tachometer, compressor, etc.
      The block was not in the car and was covered in surface rust and it also didn't have main caps. The block which is in the car is from '68 IIRC and it was stamped as an original would be except it was sooooo obviously the wrong block. The stamp for the engine type was the same size as the serial number so it just looked so wrong even a goob like me could tell it was fake!
      I am highly suspect of the '64 block due to the attempted stamping of the '68 block.
      • Rich P.
        • January 12, 2009
        • 1361
        John,
        it's hard to tell from the pictures but look inside the depressions made bty the charactures and see if the pitting is in there also. If no pitting in the #'s then I'd have some doubts.
        Rich
        • Paul J.
          • September 9, 2008
          • 2091
          I'm certainly no expert either, but should'nt there still be some telltale evidence of broach marks even with the pitting?
          Paul
          • Rich P.
            • January 12, 2009
            • 1361
            Paul
            Paul,
            in most cases yes but I restored a 300hp 67 about 15 years ago and before it was brought to me the car sat outside for 12 years with no hood intake or heads. The stamp # were still there but all traces of broach marks were gone. This was no doubt the original motor from the car as my customer bought it in 71 and was untouched.
            Rich
            • David L.
              • July 31, 1980
              • 3310
              In 1964 a 327 Chevrolet Passenger car engine w/M.T. had a stamping that ended in a single letter "R". I believe the original stamping on the block was "F0512R". The partial VIN was NOT stamped on 1964 passenger car engines. I believe only the Corvettes had the partial VIN stamped on the pad. I once owned a 1963 Chevrolet 327 w/M.T. Tonowanda block stamped "T1017R" without the partial VIN stamped on the pad.
              It appears that someone added a second letter "R" (but different style) to make it look like a 1964 Corvette 327 engine w/M.T., S.H.P., and A.C. and added the partial VIN as well although the partial VIN stamping looks very original. I assume the partial VIN of your car is "4120313" , the block casting # is "3782870", and the casting date is possibly "E 10 4" or "E 11 4". What is the body build date of your car? I assume it was made about May 1964.
              • Michael W.
                • April 1, 1997
                • 4290
                Paul
                Not all blocks started out in life with discernible broach marks.
                • Loren L.
                  • April 30, 1976
                  • 4104
                  Real World, ala being kicked and dragged into:
                  A. Feb '67 Road & Track, article by R&T staffer Ron Wakefield re a '64 CV 36K miles later.
                  "The car was delivered to me with no more than a wash job,
                  apparently. Problems: a broken spark plug; the side windows wouldn't
                  roll up with the door shut; splotchy paint on top cover panel; the top
                  didn't fit properly; the passenger's seat rattled furiously; leaks around
                  the windshield; and the steering had a massive squeak in it."
                  "I've come to the conclusion that the condition of my car was
                  typical and the dealer service was typical; in my experience it seems
                  most Chevrolet dealers look upon the Corvette as some kind of
                  Funny Furrin Car."
                  (Perhaps I should add that the writer liked his car!)
                  B. If the car you present on the judging field has been repainted, it DESERVES a deduction for over-restoration. No painter who is charging you _____dollars per hour is going to miss the spots the factory did - because the customer won't pay. (This is why Flight judges should be required to attend Bowtie judging and listen to things like "Yeah, it dammed near doesn't have any paint between the park lights, JUST LIKE NORMAL."
                  But that ship has sailed, gentlemen. I, personally would like to seem some things recognized as NEEDED, ie, the low spot on the forward part of the right rear quarter on '61s & '62s - it doesn't offend the eye, but when it has been filled, to me it's a deduct.
                  • John C.
                    • January 1, 2001
                    • 171
                    June 22, '64, and yes the vin is 4120313. There is also pitting in the letters.
                    • Bob H.
                      • July 31, 2000
                      • 789
                      As for the second R it could have been more pressure when stamped yet,
                      I have owned two 64 RR engines. One, the engine had never been out of the car. Neither seemed to have what appears to be two perfectly straight set of numbers. On one of mine, the last R barely made the surface. It seemed to me whoever stamped these things didn't care past getting it on the pad. Just my 2 cents.
                      • Jim D.
                        • 2882
                        In the spring 1995 issue of Corvette Restorer, Al Grenning wrote an article on stamp pads that explains this common occurance.
                        • John C.
                          • January 1, 2001
                          • 171
                          It's a common occurrence that the R is stamped in a different style, or that passenger car engine blocks have stamps added to make it look like a Corvette?
                          I don't keep Restorers and I wouldn't have any that go back that far anyway.
                          Would you be willing to copy it and send it to me?
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17549
                            John, Restorer's are on CD-ROM available from the NCRS Store. Gary....
                            NCRS Texas Chapter
                            https://www.ncrstexas.org/
                            • Martin M.
                              • November 1, 1979
                              • 124
                              Sure Looks like faint Broach Marks on the Rail Just above the pad. What say ye?
                              Marty
                              Beautiful Pahrump, NV.
                              No smog, no rain, no winter, no hurricanes, no tornadoes,
                              no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
                              vetteheads.com alumni, Boston MA alumni
                              1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
                              1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
                              1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
                              1957 Chrysler 300 C 392 Hemi Car
                              All for sale - most not cheap!!!
