PPG mixing question - NCRS Discussion Boards
PPG mixing question
  • Tom L.
    • May 7, 2007
    • 438
    PPG mixing question
    I'm painting a steering column with PPG Shop-Line JAU direct gloss acrylic urethane. The supplier sold me a matting agent to dull the gloss and a hardener (JH6670). I was told that this was all I needed.
    I pulled up the technical data sheet online before mixing and I see that the mixing ratio includes a reducer. Do I need a reducer? Thanks.
  • Dick W.
    • 10483
    Re: PPG mixing question
    If the technical data sheet said it did, you do
    Dick Whittington
    • Tom L.
      • May 7, 2007
      • 438
      Dick,
      That's my problem with the way it's written. It's silent as to whether you do or do not need it. It only gives a mixing ratio. The matting agent is also in the mixing ratio. That isn't always needed either. I just don't know if it's okay to use this stuff without the reducer. I'd hate to wait until monday to call and ask since I'm ready to spray now.
      • Wayne W.
        • April 30, 1982
        • 3605
        Why dont you spray something else and test it.
        • Tom L.
          • May 7, 2007
          • 438
          I just tried it. The paint was very thin without reducer. It went on well. So far so good.
          • Timothy B.
            • April 30, 1983
            • 5177
            Tom,
            On the flattening agent can does it give and additional mixing instructions. I remember on some PPG urethane I used a few years ago the flattening agent is used in place of reducer.
