Kinda Silly Electrical Question - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Kinda Silly Electrical Question
    The problem you are having is exactly the type I have had with many alarm systems. To begin with the frame has nothing to do with the ground. A small detail is riveted to the fiberglass fender so the only ground is through the wire. Many horns will test fine on a battery but refuse to sound when installed. My alarm would only sound with the hood switch at home before the regional in June but a trip in the trailor with all the bumps in Chicago fixed it and it worked fine for opps. If you find the problem please post the fix I'm all ears.
    Lyle
    Lyle
