Re: Overheating and backfiring
At 550 rpm there's no perceptible rpm drop and timing change when removing and plugging the vac hose.
Since there's vacuum produced (vacuum gauge shows this) the vac isn't working ... at least at this rpm. Since there's a rpm drop at higher revs the vac is at least working.
Should the vac perceptible contribute to timing at idle - here 550 rpm - for a stock '65 300hp, Carter AFB engine configuration?
Oliver
Oliver
