Hey all,
Does anyone know the correct size, plating and headmark of 1966 AC plastic ducting mount screws? These are the ones that screw from under the left and right hand duct assemblies. Also, if anyone knows the same stats on the "D" clamp screw that joins the right AC duct to the inner pan outlet, it would be most appreciated.
Thanks, Mike
Thanks, Mike
one or more of these is correct. They're all 5/16" recessed hex, you can see two have integral flanges. The one with the "L" headmark has some reddish-orange coloring, so obviously this is wrong. I'd bet the washers are wrong as well
