Question about a 69 l36 7029215 carb - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    On a car I'm looking at I verified it has a quadrajet 7029215 carb on it.
    right after the 7029215 it said 2 more digits I couldn't really make them out leaning over the car I could only make out the 7029215 because I kinda knew what numbers to look for (i wear contacts my eyes are horrible!)
    anyway It looked like 68 or something after the 7029215 it oculda been letters? no clue.
    question is, does that sound correct or is this a service replacement carb or something? I thought there would be a 4 digit date code after the 7029215 numbers...
    any help is appreciated, looking at this car at carlisle so tomorrow I'll be looking at it again.
  • Terry B.
    • August 31, 1999
    • 607
    Re: Question about a 69 l36 7029215 carb
    Brandon,
    The numbers are correct for a '69 with 427/390 4 speed. Rochester Quadrajet carbs will have a 4 digit date code next to the part number, however some Rochester carbs were manufactured by Carter for GM and will be so identified. Carter - built Quadrajets carbs use a different date code than Rochester built units. The code for Carter is MY, where the first digit is the month and the last digit is the year. A 68 after the part number would be June of 1968. Good Luck
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Brandon T.
      • October 23, 2008
      • 872
      Originally posted by Terry Buchanan (32872)
      Brandon,
      Ah ok because I was pretty sure it had the numbers 68 after the 7029215.
      so, thats an indicator that it was made by carter correct?
      man wish I had known that, that and a few other things turned me away from the car I figured with a 2 digit code instead of a 4 digit it must have been a rebuilt carb the dealer put on or something.
