67 327/300 HP Water Pump Question - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Are all four bolts on the water pump suppose to be painted engine orange? My car has a 327/300 hp engine with air conditioning. Thanks.
    Kirk
    Re: 67 327/300 HP Water Pump Question
    Kirk
    Kirk----
    I believe that for your application the upper left (driver) side bolt and the lower right (passenger) side bolt were unpainted. The other 2 bolts were painted engine color.
    • Kirk M.
      • June 30, 2006
      • 1036
      Joe,
      Any way I can find out for sure? The card in the bolt bag from LICS said to paint the upper driver's side bolt orange but said nothing about the other 3. Why would this be different? Is it because of the addition of air conditioning and movement of the alternator, or are all water pumps done that same way? Thanks.
      Kirk
        Joe,
        Kirk
        Kirk----
        The upper, driver side bolt was installed at St. Louis. I don't know why it would have been painted. For base engine with C-60 applications the lower passenger side bolt was also installed at St. Louis, so I don't know why it would have been painted. The other two bolts were as installed on the engine at Flint, so they should be painted (even though the upper passenger side bolt was removed and re-installed for the compressor bracket).
        As far as finding out for sure goes, it will take observation or reports from known-original cars of your configuration.
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          Hi Guys,
          Lengthy thread last week on that D/S upper bolt head.
          If I recall the consensus was that since the alt bracket attached at Flint was moved to the D/S for C60 in '65 and remained there in both Base and C60 throughout '66 & '67 was painted with the engine and that painted bolt from Flint was left in tact through the engine dress process.
          HaND
            Originally posted by Mike Murray (25129)
            Hi Guys,
            HaND
            Mike----
            I didn't view the recent thread you mention. However, as far as I know, the only alternator bracket that was painted with the engine for 66-67 small blocks was the lower bracket. The upper brace was not part of the engine assembly. The upper, left waterpump bolt attaches both the the lower bracket as well as the upper brace. The AIM indicates that the bolt was installed at St. Louis. However, I suppose it's possible that an existing bolt was used, assuming that a bolt was installed at this position from Flint.
            For 1968-1969, which has a nearly identical alternator mount configuration, no bolt was installed at this position and a stud was installed at St. Louis. This exact configuration was also used for 1966-67 with K-19.
            • Kirk M.
              • June 30, 2006
              • 1036
              OK, now I see why this isn't an easy question. Let's start with this idea
              Upper Bolt (A) Upper Bolt (C)
              ORANGE
              Pass Drivers
              Side Side
              Lower Bolt (B) Lower Bolt (D)
              ORANGE
              So, based on that configuration, which bolts should be painted orange. Mike, are you saying the bolt LEFT behind would have been painted orange since the bracket was moved? So, which bolt are we disagreeing on "B" or "C". Thanks.
              Kirk
              • Kirk M.
                • June 30, 2006
                • 1036
                Also, does the addition of PS make any difference?
                Kirk
                • Kirk M.
                  • June 30, 2006
                  • 1036
                  For some reason the formatting didn't come out on the message. So, let's try this one more time
                  Pass Side
                  Upper Bolt (A)
                  Lower Bolt (B)
                  Drivers SIde
                  Upper Bolt (C)
                  Lower Bolt (D)
                  So far, we have orange paint on upper pass bolt "A" and lower drivers bolt "D".
                  We also have one vote for and one vote against for orange paint upper drivers bolt "C".
                  Do you have the link to the other thread about this?
                  Thanks.
                  Kirk
                  • Mike M.
                    Director Region V
                    • August 31, 1994
                    • 1463
                    Hi Kirk
                    I just re-read the thread, but, couldn't figure out how to post the link here, so,
                    Check the archives for "Alternator Brackets 1965", William Garrett, Aug.16, 8:04 p.m.
                    The post does not specifically address the bolts, but, interpreting the re-read, the D/S upper bolt would be as I stated above, with both D/S bolt heads being engine orange.
                    Perhaps someone else may have a varying interpretation or confirmation.
                    Hope this helps
                    HaND
                      Pass Side
                      Upper Bolt (A)
                      Lower Bolt (B)
                      Drivers SIde
                      Upper Bolt (C)
                      Lower Bolt (D)
                      Kirk
                      Per the '67 Assembly Manual:
                      A = Painted - called out as "production bolt" (C60, C1)
                      B = Not Painted - added at St. Louis (C60, C1)
                      C = Not Painted - added at St. Louis (6, A2)
                      D = Painted - not touched at St. Louis (6, A2)
                      • Kirk M.
                        • June 30, 2006
                        • 1036
                        Thanks John.
                        Kirk
