1967 battery cables - NCRS Discussion Boards
1967 battery cables
  • Ara G.
    • January 31, 2008
    • 1108
    1967 battery cables
    Which parts supplier has the best battery cables? I found what I believe to be an original positive battery cable that is in excellent condition. It is 17 inches long, black and had part number 6286180 which is the correct part number but am not sure about the cable length. What about a supplier for the negative cable? Who's got the best? I am prepping the car for Kissimmee so I obviously going for Judging points..Any help???? thanks ARA
  • Glenn D.
    • May 31, 2002
    • 137
    Re: 1967 battery cables
    Did you check Lectric Limited ?
    • Ara G.
      • January 31, 2008
      • 1108
      Thanks Glenn. I ordered a pair from them today. I was going to order a set of correct spark plug wires, but they only sell 1st quarter and 3rd quarter dated wires. My car is a very late build, in the last 1000 of the 67's produced so my June build car should have 2nd quarter wires I would think. I passed on the wires for now as I need to confirm which quarter wires I need. Thanks for the info, I didn't even recall Lectric until you mentioned it to me. Regards. ARA
      • Brian M.
        • February 1, 1997
        • 1837
        1st quarter wires should be fine.
          Ara -
          The reason they only make 1st and 3rd quarter wires is because of the NCRS six-month rule - doesn't matter when your car was built, one of the two quarters will be correct for it.
