Folks;
Planning on bringing the 1965 to Mass. in September for the PV... One last thing that I am working on is the set up/function of the windshield washer and wipers.
In the AIM (thanks to Pappy for pointing this out) it shows the target areas for the washers as well as the "sweep" and resting positions for the wiper arms.. Two questions...
1) What do folks use to adjust the height of the washer nozzles??? A common sewing needle won't do, don't ask how I know..
2) On the wiper arms, are there any tricks to getting them properly aligned.. Is there an adjustment to lengthen or shorten arm length?? On mine, I can get them parked properly, and match the AIM dimensions but when they sweep they almost touch the window molding and somewhat interfere with each other when they park.. if they were a tad shorter the clearances would be better..
Any help is appreciated... BTW these are repro arms I am talking about.
Thanks!
Joel
Thanks!
Joel
