Comments on this VIN tag? - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    Any thoughts on the originality of this tag?
  • Tom D.
    • September 30, 1981
    • 2126
    Re: Comments on this VIN tag?
    Is the area behind it scratched as much as the area around it? Might be from a diff. corvette. Does it match the number on the frame?
    td
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Edward M.
      • November 1, 1985
      • 1916
      Look at it as if it were an engine pad, then tell me what is wrong with it. Remember look at both the "pad" and the "stamps".
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Hmmmm....the vin# on your photo is "back" stamped right? Also the left/right ends appear to be cut off. i.e. the edge should be ridged around the entire circumference.
        The vin should be stamped from the front, leaving deep depressions, correct?
        Rich
        p.s. I own a 59, and my vin tag doesn't look like that. I'll have to got look at it again.
        • Bill M.
          • April 1, 1977
          • 1386
          The embossment goes all around except at the screw holes.
          The VIN is stamped from the front, not the back. It doesn't show much on the back surface and you can't feel the characters.
          My '59 VIN is not centered, but offset to the right.
          • Richard T.
            • February 1, 1979
            • 858
            This is a bogus vin tag. The vin number should be stamped from the front and justified to the right. The tag itself should have the raised ridge all the way around not just top and bottom. Rich
            • Edward M.
              • November 1, 1985
              • 1916
              Yep. Here is pic of a correct appearing 59 VIN tag. A bit hard to see, but the differences are apparent.
              This "59" in question is currently on Ebay as a project car.
