Rear Leaf corrosion....too much? - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Here are some pics from a 1971 rear leaf spring after disassembly and light clean up. I was hoping to restore but now have my doubts.
    Is this amount of corrosion / pitting excessive or should I chillax and let er rip.....?
    Thanks...
  • William C.
    • May 31, 1975
    • 6037
    Re: Rear Leaf corrosion....too much?
    Jim, given the degree of pitting, I'd look at replacement.
    Bill Clupper #618
    • Jeff S.
      • July 31, 1984
      • 383
      Jim
      I would at least replace the main leaf. You've lost a lot of cross sectional area between the cushion cup and the start of the next leaf due to that deep pitting. When I last checked (maybe 6 months ago) Eaton would sell this leaf alone -- although not cheap; as I recall it was about $145 for my '66.
      Jeff
      • Joe R.
        • March 1, 2002
        • 1356
        I agree with Jeff that if original appearance is important, a good compromise would be to replace just the main leaf. The Eaton main leaf is pretty much 100% correct in appearance, while the other leaves are about 90% correct. On the other hand, if having exact original appearance is not important, just buy the entire Eaton spring.
        • Gene M.
          • April 1, 1985
          • 4232
          replace the whole thing. The car may not sit straight if you piece it up.
          • Steve L.
            • June 30, 2001
            • 763
            Why would that be?
            Steve L
            73 coupe since new
            Capital Corvette Club
            Ottawa, Canada
              Jim-----
              By the way, the type and degree of pitting and other wear your spring leaves evidence is VERY common, even with Corvettes that have lived their lives in a "non-corrosive" environment and which, otherwise, have very little corrosion seen anywhere on the car.
              One of the reasons for this is that the springs were coated with the Ikonklad coating only on the TENSION surface (i.e. the lower surface). The upper surface was not coated and left bare steel. If both surfaces had been coated, none of this would have occurred. Usually, the Ikonklad surfaces are "pristine".
              • Steve L.
                • June 30, 2001
                • 763
                Jim-----
                Joe,
                What is Ikonklad. There is nothing in Google. I've never heard of it.
                Steve L
                73 coupe since new
                Ottawa, Canada
                  Originally posted by Steve Lischynsky (36372)
                  Joe,
                  Steve----
                  I think I spelled it wrong. It might be Ionoklad or, maybe, even some other spelling. It's the thick, gray coating that was applied to the tension surface of the spring leaves. It's usually very notable when a spring is disassembled.
                  It's available from Quanta in pint cans. They say it can be either sprayed or brushed on. I think it's way too thick to spray and I wouldn't want to thin it. Just apply it with a brush to a CLEAN, NON-OILED surface. I apply to to both sides and edges of the spring leaves.
                  • Steve L.
                    • June 30, 2001
                    • 763
                    Joe,
                    Ionoklad made by United Paint and Chemical Corp.
                    This is a patented zinc-rich welding primer developed in 1961
                    I don't see it on the Quanta site. The patent has probably run out. I see this kind of stuff at most welding stores.
                    Steve L
                    73 coupe since new
                    Ottawa, Canada
                      • 11608
                      Steve,
                      It's there - but not listed under the Ionoklad name:
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        Steve, the spring may not exert the same force at each end if assembled with used leafs that are not assembled in the same direction as disassembled or not virgin to the assembly. The deep pitting and corrosion results in different (less than new) deflection forces. I can assure you it is not even corrosion on both ends of each individual leaf. So assembling it back as it was will not be same resultant force deflection on both ends.
                        A spring shop can balance and re-arch it to give functional assembly. But why not use a whole new spring and avoid all that work, expense and time?
                        • Steve L.
                          • June 30, 2001
                          • 763
                          Steve----
                          I think I spelled it wrong. It might be Ionoklad or, maybe, even some other spelling. It's the thick, gray coating that was applied to the tension surface of the spring leaves. .
                          Joe,
                          Why would they only apply it to the tension surfaces?
                          Maybe they are thinking that stress cracks introduced because of corrosion on the tension side is more deterimental than on the compression side.
                          In any case, you'd think that dipping the whole spring in a tub would be easier than brushing or spraying one side only.
                          Steve L
                          73 coupe since new
                          Ottawa, Canada
                          • Steve L.
                            • June 30, 2001
                            • 763
                            Because we have all read about how none of the aftermarked springs give the correct height. And once I re-install it and get the body back on, I wouldn't be in very good humor, if the body was way up and I had to redo-the spring again.
                            What you say about the corrosion not being equal on both sides resulting in unequal forces makes sense. But I wonder if the corrosion was that bad, the spring would be toast. Which brings back the OT question "how much corrosion is acceptable?"
                            I would suspect that it depends on where it is, how deep it is. If it's near the diff and on the tension side, it would be worse than if it's on the ends.
                            My main leaf broke right in the middle under the diff bolts, 3 of the 4 bolts were broken, the diff ears were broken and the top spring had a corner missing. By some miracle the whole thing held together. I stopped driving it when I noticed the ears broken. But it wasn't obvious that the main spring was broken until I took everything apart. I didn't see any excessive corrosion to warrent the break. But it was broken for a long time since the break edges were well rounded from wear.
                            Steve L
                            73 coupe since new
                            Ottawa, Canada
                              Joe,
                              Steve-----
                              I don't know why the coating was applied to the tension surfaces only. However, that's what it says on the prints for the spring and that's exactly how it appears on every original spring that I've dis-assembled. Usually, though, the coating was rather "sloppily" applied and the edges and a small portion of the adjoining upper surfaces of the leaves got coated, too. The reason that only the tension surface was called out to be coated may very well be exactly as you've surmised. That's what I always figured, myself.
                              Also, ANY pitting type corrosion on the spring WILL affect the functionality of the spring. That's the inherent nature of a spring. It will also render the leaves more susceptible to breakage. How much is too much? It's impossible to quantify. However, one may find out when a spring leaf breaks in service. That's called the "empirical method" of determining how much is too much.
