Brake linings ID - NCRS Discussion Boards
Brake linings ID
  • Loren L.
    • April 30, 1976
    • 4104
    Brake linings ID
    I've run across 1 axle's set (2 primaries, 2 secondaries) of brake linings that are BONDED to shoes stamped DELCO MORAINE DAYTON OHIO and
    "5459726".
    The lining material is steel gray and not cerrametallic (sp?); TWO segments on the secondaries that each measure 2 1/2" wide and 3 3/4" long; THREE segments on the primaries that measure the same 2 1/2" X
    3 3/4".
    Are they HD linings for passenger car application? Did Delco ever offer a rebuild of the earlier Corvette HD shoes and decided that the "small" segments found on those shoes to be unnecessary? Or?
    Thanks.
  • Jim L.
    • September 30, 1979
    • 1805
    Re: Brake linings ID
    3 3/4".
    These sound like a set of Velvetouch re-lined shoes. Velvetouch used available cores and attached their metallic friction material.
    Can you post pictures?
    Jim
