I don't post much on this forum but I thought I'd share my experiences on the interior restoration project of my '66 that I've had for almost 24 years. In the process of stripping the interior, I've found that it was all original. That's the good news/bad news tale. However, as you'll see in the photo's, I was able to preserve most of the original jute backing and have discovered a couple of interesting labels on the underside of the rear side carpeting pieces I'd like to share. Im sure there nothing new to some but for those that haven't seen them, here you go. I have some clean up to do but all in all, it was a pretty clean extraction.
Now a question for the experts..... As you can see there is some rust on the deck lid hinge brackets and spring in the back corners. Can someone tell me the original painting of these brackets? A close inspection revels that it appears to be just a real faded zinc chromate primer with a little body color and iron oxide thrown in the mix. After I clean these up, I could hit them with a light coat of zinc chromate but I have the urge to use just a flat black. Thoughts????
Thanks.....
Frank
http://www.flickr.com/photos/9543979...7622269687116/
Thanks.....
Frank
hinge bolt that attaches hinge to body mount brackes to be rusted round. I wanted ro remove both of the deck hinges but find a bolt on the quarter panel side of each hinge to be impossible to get to. Does any one have any suggestions other than an hour with a 1/4 inch drive?
