C1 Door Molding - NCRS Discussion Boards
C1 Door Molding
  • John C.
    • September 30, 2001
    • 130
    C1 Door Molding
    I want to remove these molding strips from my door, do I have to remove the door panels from the inside to get to the clips holding the strips?
  • Karl L.
    • February 1, 1977
    • 174
    Re: C1 Door Molding
    John.
    On a "53"-"55" they snap on to the clips. They should pop right off using
    a flat thin tool. Be careful tho with the paint and stainless.
    The Gull Wings, if you have to remove them, have a nut type fastener.
    3 Per Wing.
    Karl.
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: C1 Door Molding
      You could probably get the trim off the clips without removing the door panels, but if you want to remove the clips or re-install the trim the door panels will have to come off.
