My '75 is back from paint , with a fresh rebuild, (using the Comp Cams 354 H grind that I wrote about earlier this summer)and largely reassembled. Now I'm trying to work on driveability issues.
Initial idle problems ( loading up and stalling when placed in gear ) were cleared up with a Summit rebuilt Qjet....engine starts fine, idles great.
Problem occurs when advancing the motor past 1500 RPM ( had the same issue with the original Qjet that I rebuilt).
I have the initial timing set at 8 BTDC
Centrifugal advance is giving me:
0 at 750
22 total (14 advance) @ 1500 rpm
Can't maintain a steady state above 1500...have to "race" the motor, which does run the advance higher, but I can't say how much.
Using the stock VAC. ( gives me 30 total at 750 rpm ..13" vac)
While trying to steadily increase RPM, when it hits 1500, vacuum begins to drop, carb gets that "sucking" sound. If I keep advancing the throttle, engine slowly comes up, but is really sluggish. Waaay to much throttle for the engine speed. No "lean" backfire or spitting. On the street, the motor sounds fine until I try to push it past the flat spot...
New dual exhaust, no heat riser.
Fuel tank was clean when the resto was done, I installed a new screen, all new fuel hoses, new fuel pump. I guess I could have pinched a fuel line somewhere at the tank or by the pump.
This is the problem with a total frame on that included a distributor and carb rebuild....too many places to look.
One minute, I'm convinced that it is running out of gas, the next, I believe that it is ignition...
I'm open to all suggestions ....
0 at 750
Thanks to everyone for the input...I'll post pix next week, now that I can get back to work on the trim!
