1967 windshield washer pump - NCRS Discussion Boards
  • Richard W.
    • April 30, 2006
    • 3
    Hello, again. Owner 1967 convertible 327. My windshield washer pump does not work. I tried the repair kit, but couldn't get the 'bell' off to replace. Then I bought a replacement from Ecklers, and installed, but it still doesn't work. I tried to prime the intake tube without success. Any ideas? Rich Weddle
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 1967 windshield washer pump
    Rich,
    are you getting power to the terminals at the pump?
    Rich
    • Gerard F.
      • June 30, 2004
      • 3803
      Here's a thread from the archives which might be helpful:
      https://www.forums.ncrs.org/showthre...36140&uid=4232
      Here's the picture that goes with the thread:
      Here's a couple of other pictures that might be helpful:
      Original on the left, replacement bellows on the right. To remove (or replace), stick your thumb in the bellows, push against the spring, and turn the bellows 90 degrees.
      Here's a layout of the various parts of my 67 washer pump:
      The main problem as I found were the quality of the little rubber parts in the replacement check valves. Sometimes a little vasiline or Sly-Glyde on the rubber parts give you a better seal.
      Have fun,
      Jerry Fuccillo
      • Patrick T.
        • September 30, 1999
        • 1286
        Jerry, I wish I would have seen this post about two weeks ago! I was going nuts out trying to get the bellows out, while the pump was still on the car. I never could get it out, so I just installed the white nozzle kit. Rubbed in some silicone dielectric grease on the gaskets and now it works like a charm.
        If properly installed, you should only need to prime the pump one time. If the system does not stay fully charged all the time, then there is a siphon breaker somewhere in the system, which lets air into the system, breaks the siphon and the fluid drains back into the reservoir. PT
        • Gerard F.
          • June 30, 2004
          • 3803
          PT,
          Did you get your nozzles stabilized?
          If you are going to change them anyhow, you might just just try a set if vise grips on them.
          Jerry Fuccillo
          • Patrick T.
            • 1286
            Originally posted by Gerard Fuccillo (42179)
            PT,
            Jerry, I didn't install the bellows but the one that was already in there looked OK. I did install the nozzles and gaskets and it's been working great for the last week. I test it everyday and it's holding a siphon so I don't have to prime the unit. It works fine now, so I'm just going to leave it alone. If it ain't broke, don't fix it!
