No brakes - NCRS Discussion Boards
No brakes
  • Joe S.
    • June 2, 2008
    • 2
    No brakes
    Joe
  • Steven G.
    • November 17, 2008
    • 348
    Re: No brakes
    Joe, try bleeding the front calipers, their is the brake warning/safety valve that will need to be repositioned, I assume you have good bleeding pressure. Steve
    • Robert S.
      • June 30, 2001
      • 230
      Re: No brakes
      I had a similar problem before I realized that there are two bleed valves on each caliper and I was bleeding only one. Both must be bled.
