3247 Carb and L72 Fuel System - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    I just got my restored 3247 carb back and have a couple of questions. What is the proper finish for the following two items:
    1) Divider block that the fuel line from the pump goes to before spliting to the two lines to the carb.
    I have had two reproductions, one brass and one more of a silver
    finish.
    2) Carb Inlet Fittings
    Again, I have seen two different finishes, one blueish black and
    one closer to the color of the carb
    The car is a 1966
    One other non fuel related question. Is the ground strap attached at the back of the intake (under the ignition shielding bracket) supposed to have any paint on it. Mine is painted but I think it was sprayed when the previous owner was painting the valve covers. Not sure though.
  • Jody B.
    • March 1, 1991
    • 108
    Re: 3247 Carb and L72 Fuel System
    Larry,
    The Winter 2005 Restorer magazine shows a properly restored 3247. There's a full color picture on the back page of the magazine. That being said, the fuel inlets are definitely black. The picture of the fuel block (connecting the three lines) is fairly tarnished and has hints of having a dingy silverish look, but not sure.
    JB
    • William C.
      • May 31, 1975
      • 6037
      Unpainted ground strap, If you look at the U-69 AIM section, section A4 shows the ground strap as being attached with part number callout for St Louis install. I agree with the last poster on the carb, black inlets, silvery junction block.
      Bill Clupper #618
