I am looking for a correct air cleaner filter. (It should be a AC Delco 212CW). I am trying to buy one and the seller said that neither the mfg or cat number is on the filter, but there is a AC Delco box. Question is...should there be info printed on the filter? Dan
Air cleaner filter
Re: Air cleaner filter
It depends what you're looking for----a "correct" air filter for judging purposes or just a functional replacement. If it's the former, original AC A212CW filters did have reference to that number either embossed or printed on the plastic ends of the filter. I believe those in the 1966 to ABOUT 1969 era were embossed, with later printed in white.
If you're just looking for a functional replacement, you can still purchase this filter from GM or AC Delco dealers. The current filters are no longer manufactured by GM or AC Delco, though, and may not have any reference to type number or AC Delco on the ends, but will be in an AC Delco box. Perhaps that is what the seller you are referring to has for sale.In Appreciation of John Hinckley- Top
Daniel - If the filter is really an older AC A212CW air filter element in the original box, check the various applications and associated years. The older AC boxed listed the applications and the years of usage for the vehicle. Find the newest year of applications and the filter is either from that year or newer. For example if the box shows a Corvette application for the AC A212CW from 1965-1972 and there is an Oldsmobile application listed for an AC A212CW filter from 1970-1978 then the filter if it's the original to the box is either a 1978 or newer filter and would not be the configuration used in 1965 for the Corvette but would be functionally correct as an AC A212CW filter. Pete- Top
Those are the kind of filters you will need a home equity loan for -- if the seller knows what he hasTerry- Top
If you're looking for a 396 BB or a '66 AC212CW filter (maybe later ?) the configuration is important for the big $$$$. The box will give part # 6421746 and the AC #, but only an embossed (not painted white) # will appear on sealing edge of filter itself (pic). And mesh pattern is important. perfect square (not flattened "diamond") turned 45 degrees. You can see the soldered overlap in this pic.
Caution, as this same GM part # was used for square (not rotated 45 deg) filter mesh and diamond filters, depending on the year of manufacture. The earliest ones were as shown in the thumbnails.- Top
Wayne,
Good to see another one out there.- Top
Air cleaner filter; How good of a repro?
Lyle,
Was the repro you saw at Carlisle good enough to get fewer deducts than an incorrect GM part? If originals sell for perhaps thousands of dollars, it seems natural that someone would start making a good repro.
Gary- Top
In addition to the GR8 photos Wayne & Jody posted of their original AC A212CW air filters (Wayne & Jody thanks for taking the time to go to your Safety Deposit boxes at the bank and take these out to take pictures), I have seen an original AC A212CW from a 66 Corvette with AC Spark Plug embossed in 1/4" or 5/16" characters on the black Plastisol surround. Neat pieces. Pete
- Top
Somewhat related - I've got some recent chassis dyno test data (1967 "Special 300 HP" configuration) that shows a net loss of torque/power running without the air cleaner. The difference was small - averaging about one percent across the rev range, but it was there.
Earlier smaller SB air cleaners used prior to '66 may not follow suit since their smaller filter area yields greater loss through the filter.
The air cleaner base acts as a nozzle to smoothly accelerate the incoming air into the air horn with minimum turbulence, and the lack of this feature more than negates the loss through a generously sized cellulose air filter element.
Duke- Top
Please tell me more of this "Special 300HP" tests as I own one of these ultra rare base engine cars.Somewhat related - I've got some recent chassis dyno test data (1967 "Special 300 HP" configuration) that shows a net loss of torque/power running without the air cleaner. The difference was small - averaging about one percent across the rev range, but it was there.
Duke- Top
