C2 parts Identification - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    Can someone tell me what these parts are for. They came in a box with spare parts with my 65 Coupe.
    My guess is they came off the bottom of the car.
    Mark
  • Alan D.
    • January 1, 2005
    • 2027
    Re: C2 parts Identification
    One on left is the small shield on the right side just below battery. (is on right side)
    The other may be the battery lower support.
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Mark Pellowski (49021)
      Can someone tell me what these parts are for. They came in a box with spare parts with my 65 Coupe....
      Part on the left is the right side inner splash shield that goes against the frame (with the curved indent) and the raised edge faces the wheel and bolts to the fiberglass of the fender. If you were to slip a small object through the vertical vents in the side fender, it would fall onto this shield. Are there visible staple holes (for a rubber seal) in that edge with the indent (to clear the battery tray gussets where they bolt to the frame) ?
      The other part looks to be one of the two battery tray gussets that bolt to the frame and are spot welded to the tray, but I'm not too sure, as I don't have an example of a RH battery tray car here to compare.
      • William S.
        • June 28, 2009
        • 28
        The one on the left is a inner splash shield and the one on the right is the battery support.
