Gentlemen:
My driver side mirror on my '65 convertible is in great condition, but it is a little loose and therefore doesn't maintain its setting during the course of a cruise. Therefore, I am constantly having to readjust it along the road. The issue is not between the mirror and the door, but rather the round mirror and the bracket. In other words, the ball & socket joint is a bit too loose. Is there a mechanical way to tighten this "hip" joint, or if not, can a drop of glue (such as Krazy Glue) bind up the joint for a tighter connection that won't become "disjointed" and shift with the wind?
Your thoughts would be appreciated,
Roger (50141)
Roger (50141)
. I figured that it was worth taking a look before the easy glue fix. However, after wrestling with that retaining ring for 30 minutes, I didn't have to go far to look in the mirror and tell myself not to make this one of those large jobs. The magic mirror told me that if I kept at it, I would end up with a broken mirror and a scratched chrome frame. The dental pic sounds like a good idea, and if the glue doesn't hold long-term, I will certainly try it. I used everything in my toolbox - including a plastic fork & knife so as to not scratch anything. My intentions were good, but without the intended results. So far, the Krazy Glue is doing the trick
