Re: C2 Dash Pad Air Pocket
Kirk and Jim,
The third time was the charm
!! The Rhino Glue worked great. I would like to be the new poster child for this product. My only regret is that I didn't find it prior to the first & second attempts. The glue is a perfect consistency and flowed through the syringe & needle with ease. I wiped a little ArmorAll on the vinyl prior to injecting the glue to help wipe off any residual glue to avoid "collateral damage". After injecting the glue, I quickly massaged it around the air pocket to spread the glue and then pressed down on the vinyl using a clean T-shirt rag wrapped around my fingers (still moving my fingers around a little to make sure the glue spread). After a minute or two, the vinyl was bonded to the foam rubber substrate. I felt some mild heat through the vinyl from the chemical reaction of the glue (similar to Krazy Glue). I then injected one additional spot to make sure the entire air pocket was glued, did the massage, and pressed down as before. Now, the air pocket is completely gone
!! I don't see why it wouldn't work on a door panel as well. The only thing that kept my repair from perfect is a minor "hump" due to dried glue from the previous repair attempts. It is very minor and I can certainly live with it. If I found the Rhino Glue first, I am certain that the repair would have been 100% versus what I consider 90% - but I'm a perfectionist and I'm very happy with the results. Don't buy a new door panel or dash pad until you try this repair first. It worked for me, so it should work for you, too!
Good luck,
Roger (50141)
Kirk and Jim,
!! I don't see why it wouldn't work on a door panel as well. The only thing that kept my repair from perfect is a minor "hump" due to dried glue from the previous repair attempts. It is very minor and I can certainly live with it. If I found the Rhino Glue first, I am certain that the repair would have been 100% versus what I consider 90% - but I'm a perfectionist and I'm very happy with the results. Don't buy a new door panel or dash pad until you try this repair first. It worked for me, so it should work for you, too!Good luck,
Roger (50141)
