Gentlemen:
My black dash pads are original and in excellent condition. However, I have noticed over the past few months that an air pocket has developed between the vinyl and the foam and is getting a little larger. It is specifically located on the driver's side, all the way over to the left, and is heading toward the cluster. It not a perfect oval in shape that is 2" -3" long and about 1" or so high. I don't want to replace these original pads, nor do I want to pull the cluster and the pad to attempt a repair. My idea is to inject a glue (either "Krazy Glue Gel" or "Tear Mender") with a needle and syringe into the delaminated pocket and then hold it down for a few minutes until it bonds. Once I am done, the 1 to 3 small needle holes should most likely not be noticeable. If they are, they can be touched-up with a vinyl repair patch kit. The rest of both pads are near perfect. What do you think?
Your guidance is appreciated,
Roger (50141)
Roger (50141)
. I became concerned about using Krazy Glue since some glue seeps out of the tiny hole in the vinyl until you wipe if off. With KG, that could be a huge disaster
