I dare not use my factory A/C when the car is in traffic or if the air temperature is over 90 degrees. I have been told by numerous sources that cars like mine will never keep their coolant/engine cool (under 230 degrees) when running the A/C under those conditions. Some have told me that Chevrolet made a big mistake putting A/C on the L76 engines. I find this statement incredible since A/C was an option for the big block engines.
I have had experts set and reset the ignition timing until I am sick of paying for it. I have changed to richer carb jets, replaced the fan clutch, checked my 7-bladed fan, changed to a new DeWitt's aluminum radiator ($900), changed thermostats, checked for collapsed hoses, IR'd the various spots, etc. to no avail. I have done everything that this forum has suggested except change out the water pump or dismantle the engine.
I want to keep my car "NCRS Top Flight" original to do well in upcoming regional and national flight judging. So, I am reluctant to do anything at this time that would make my car appear less correct. So, electric fans and a larger radiator is not in the picture.
But, I noticed in the Long Island catalog that for a 1966 small block with A/C, there are upper and lower radiator "seals" listed (sec. #26). Other than these seals being incorrect for a 1965 (according to the catalog), would the installation of these '66 upper and lower radiator seals help my car run cooler with the A/C on, in hot weather? What say you experts out there?
