C1 Fuel Pump - NCRS Discussion Boards
C1 Fuel Pump
  • David L.
    • December 1, 1981
    • 116
    C1 Fuel Pump
    A question for application of early or late ... a fuel pump for a 1958 with an engine casting date of late December 1957. I checked the judging guide and it states 4445 with forward fuel outlet as early and 4656 with rear fuel pipe outlet as late through 1960. The aim lists part # 5594656 and it is drawn with the rear fuel outlet. Any input would be appreciated.
    David
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Fuel Pump
    David
    Can this help?
    • David L.
      • December 1, 1981
      • 116
      Re: C1 Fuel Pump
      Roy.
      Thanks for the reply. I'll print and include your info in my
      files. The engine I have has no fuel pump and I'm looking to buy one, but need to know which one is correct.
      Thanks again,
      David
        Re: C1 Fuel Pump
        Both are correct depending on whether the car is early or late with respect to this running change (fuel pump 4445 -> 4656). You should see the call out change in your copy of the AIM along with an AIM date for the change. Noland Adams' book says the change was effective 11/18/57.
        BUT, we know running changes were loosely implemented depending on how much of the prior inventory was on-hand in-plant. So, use that date as an 'approximation' of when the earliest 4656 pumps might have been seen...
        Typically, production was mix-mode until all of the prior part that was in inventory was used up!
        • David L.
          • December 1, 1981
          • 116
          Re: C1 Fuel Pump
          Thanks for the approximate date, Jack! Just for my own clarification, where in the AIM does it show the callout change and date. I am looking at section 6, sheet 3.00 and don't see this referenced. Is it on a different page?
          Thanks again,
          David
          • Loren L.
            • April 30, 1976
            • 4104
            Re: C1 Fuel Pump
            Thanks again,
            David
            Technical Service Bulletin DR #321 dated October 29, 1957 calls out that a squeaky noise "similar to a rocker arm ball speak" may be coming from the fuel pump. The fix is enlarging the forward vent hole to 1/8".
            It then lists Service package #5821638 for Corvette; #5594445 as "Old" for the Corvette, and #5594663 as "New" for the Corvette.
            Assembly plants a advised to "rework" all pumps until the new ones arrive.
            You can identify 4445 pumps that have been reworked by GREEN PAINT
            on the last 4 digits.
            • David L.
              • December 1, 1981
              • 116
              Re: C1 Fuel Pump
              Thanks, Loren. Very interesting how things worked at the assembly plant.
              David
