T-3 HEAD LIGHTS on eBay
Re: T-3 HEAD LIGHTS on eBay
I'm just curious, did anybody ever tried to cut the back of a T3 burned light of (e.g. with a Dremel) to transfer it into a housing for a regular light bulb? Is this feaseable?
regards,
Rob.Rob.
NCRS Software Developer
C1, C2 and C3 Registry Developer- Top
The prices above are cheap for clear working original bulbs. If you have spent time going through Salvage yards trying to find these bulbs you would have a much greater appreciation for the work someone else does in finding them. Snakes, Hornets, Mosquito's. rusted together parts, burly yard owners.
One time my son and I flew to Nevada from St.Louis to go through some dry Salvage yards. My son thought the owner was a pirate and the yard dog just about attacked us foaming at the mouth.
A real father son corvetting experienca.
We still have boxs of T3's stashed away. During this time we also received the T3 blueprints from the GM supplier and some years ago I posted the chart that shows how to decipher the date code stamped on the back of the bulbs.
If you are looking for bulbs don't forget to check your local shows for Cadillacs, Chevrolet, Olds etc..they are usually priced less.
Joe Trybulec- Top
I do not think this would work. I believe the vacuum would be lost and a vacuum is necessary for the bulb to work. Maybe others can give their input.- Top
I wasn't talking about a repair but transferring the body of the bulb into a regular housing for normal halogen lights...
regards,
Rob.Rob.
AT Carlisle someone told there is an individual that is doing just that. He is cutting out the back and inserting a modern halogen bulb. He then replaces the cutout and has a working bulb with the correct lens. If this is true - good for him!!
Jeff- Top
- Top
After judging my T3's are getting stored and the halogens are going in my 1960. I think candle power is stronger than sealed beams. I might even opt for Zennon. Stewy- Top
- Top
