I have decided to get my trailing arms refurbished over the winter.
before I have a problem not sure if they were ever looked at.
Before I take them out should I reference the drive shaft yoke with the trailing arm spindle . (Sorry if I don't have the correct name.) example place a couple punch marks ? Or can the rear drive shafts be installed on either side. I would also make sure the u-joints are good at the same time. I will also make note of the shims.
Any other advice on what to look for in advance would be helpful.
Thanks in advance.
1964 drum brake
Thanks in advance.
1964 drum brake
