1964 Master Cylinder casting number - NCRS Discussion Boards
  • Mike M.
    • August 31, 2006
    • 23
    I have a 64 with manual brakes, the master cylinder has the 7/8 stamping on the top and the casting number 5464264 on the bottom. There is no date code on the bottom of the cylinder. I have not been able to locate what the correct casting number is for this model year. Is this an original casting or a replacement? Thanks for the help!
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 1964 Master Cylinder casting number
    Base and power unit cast # 5464264 Power brake unit will have bleeder screw on the casting boss facing the engine.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Mike M.
      • August 31, 2006
      • 23
      thanks, I went through every different magazine article I had...but wasn't a subscriber to any of them until 2002.
      • Richard P.
        • May 31, 2002
        • 190
        Does anyone have a similar article on C-1 master cylinders?
