I took my 60 out for it's first little test drive yesterday and among other things I noticed that it seemed to run around 210 which I thought was pretty warm.
The engine(stock 283) is supposed to be rebuilt and I never got above about 30 mph in town so that might have something to to with it....or not.
What temp should it normally run at and is there a reliable and easy way to check the accuracy of the gauge? I could take the sender out and boil it in some water and check the gauge and it should boil around 205 or something like that at my altitude but that's a bit of work.
I was also thinking about getting one of those infared guns but I'm not sure how accurate they are and if there would be much of a temp difference between the surface temp of the sending unit and the actual temp of the coolant.
What would you do?
What would you do?
