I have my frame at body shop being epoxy primed / painted. There is a section of what looks to be like weld material on top side of frame, under area where the master cylinder would be. See first two pictures attached. The car is a 1970, LS5 with automatic. Does anyone know what this might be and do you recommend I have it grinded off before proceeding?
On radiator support, there is an indentation in the center, leading edge for front grille bracket. At both ends of the indentation, there is a small split in the metal. See picture for one side. The other is identical. Has anyone seen this before and do you think it was caused by the tooling? Hereagain I am wondering if I should repair with weld/grind or leave as is. Comments/suggestions appreciated. Steve
