TI wire harness - NCRS Discussion Boards
TI wire harness
  • Paul L.
    • April 30, 1995
    • 2
    TI wire harness
    Hello, I was hoping someone could ID this harness part number-
    Gr. 2.480 #2980888 last two numbers are faded and may be 08
    thankyou
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: TI wire harness
    thankyou
    T.I. amplifier harnesses are under Gr 2.383. Under that group, closest is 2988218 for '64-67 Passenger w/T. Ign. (396, 427).
    Under 2.400, the closest I can find is 2980982 '56-62 (cover 148" overall length) (w/junction block). Can't see anything close even in the Chev P&A30 1967 catalog.
    Maybe Joe L. can come up with something.
    • William C.
      • May 31, 1975
      • 6037
      Re: TI wire harness
      The '73 price book lists the following "close" numbers in that group: 2908858, 2908860, 2908868. 2980916. If the group number is correct, the possibilities are: 2908868-55-65 A/C jumper harness to gen, 2980805, 62 pass with A/C gen extension. Those are the only items I can find in that part number sereis, and it should be noted that that number series was a Packard electric series, from the 1962 era.
      Bill Clupper #618
      • Michael H.
        • January 29, 2008
        • 7477
        Re: TI wire harness
        thankyou
        If you have at least the first four numbers of the seven digit part number, 2980xxx, the part/harness was originally used on a 1962 something. Probably pass car?
        If it's actually a 2980868 instead of 2980888, it would be a 55-62 passenger car with 6 cyl engine gen harness. The length is shown as 51 5/16".
