The 55 vette 265 ci pass side exhaust manifolds/header pipes were cast/formed in such a configuration so as to come extremely close to the #6 and #8 spark plug wires/boots as well as the + battery cable and starter portion of the ignition harness. Dave suggested an insulation be placed over the aforementioned wires. i found a product that works well. Thermo-shield by Cool It/Thermo Tec. The product comes in a roll(god only knows the length--a buddy gave me the remains of his package) and is 1 1/2" wide. ya simply cut to length a piece, remove the paper backing to expose the sticky adhesive side, and then wrap the wires at risk.the manufacturer claims 2000 degrees radiant heat protection. mike
Neat tip courtesy of Dave Ferguson
Re: Neat tip courtesy of Dave Ferguson
I did that many years ago because of all the driving we do in our 55.
Mike I just remembered to add this pic. Of the 50's bake-a-light wire ends I used when the original ends get hard and short out for driving , for NCRS I replace them with an other original set.- Top
