Can anyone help with a description or pics of the bolt/washer arrangement of the upper radiator brackets that bolt directly to the support? I know the brackets are attached with 2 bolts each, but am not sure of the washer/star washer/lock washer sequence. The support is for a copper radiator. Any help is appreciated. Tx.
70 Radiator Support
Re: 70 Radiator Support
The washer sequence is shown in the 70 AIM, UPC LS5, Sheet B4.Can anyone help with a description or pics of the bolt/washer arrangement of the upper radiator brackets that bolt directly to the support? I know the brackets are attached with 2 bolts each, but am not sure of the washer/star washer/lock washer sequence. The support is for a copper radiator. Any help is appreciated. Tx.
All the bolts have star washers except for the upper bolt on the passenger side bracket which inexplicably has a large fender type flat washer and a cut lock washer. This arrangement is the same for small blocks with C60 and copper/brass radiator.
A search of the archives may turn up a discussion of this feature many years ago, but I wouldn't bet on it. As I recall, Ron Goduti was the man with the definitive answer. I had noted this washer difference during disassembly, but wasn't sure it was original or remember which bolt was configured differently.- Top
Joe, the aim shows star lock washers, but my 72 C60 car has big star washers on the outboard and flat washers on the inboard all appear to be original to the car and appear to be zinc plated.this may vary from 70.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Chuck-----The washer sequence is shown in the 70 AIM, UPC LS5, Sheet B4.
I've never figured out the reason for the split-lockwasher at the one position, but I think I know the reason for the flatwasher. Without it, the radiator support is easily distorted when the bolt is torqued to spec. In fact, they should have used a flatwasher at ALL positions.
Maybe they discovered that by 1972 and that's why Edward's car has them at all positions even though the AIM doesn't call for it.
I used flat washers at ALL positions. In fact, they are more necessary at the positions that use star washers than they are at the position that uses the split lockwasher. Using the star washers in this application without flat washers was a VERY "hokey" sort of design.In Appreciation of John Hinckley- Top
Joe, I Ref. My 72 Aim Page M325 It Shows Flat Washers Pt. No 3748358 On He Condenser Bolts, Is The 70 Aim Show The Page As My 72 Aim And The Flat Washers, On Another Page In Aim For 72 , 3 Star Washers And One With Flat And Lock Washer .it Is Conflicting.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Could someone tell me what headmarks were on these bolts and are the lengths all the same or are they different? Also what finish on the bolts?
Sheldon- Top
Sheldon,
My 72 C-60 car has a WB on the outboard bolts they were shorter bolts, And the inboard bolts where RSC and were the longer bolts.I would say the shorter bolts were about one in. and the longer inboard bolts were about 11/2 in. long. there were zinc plated as was the washers including the star washer.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Hmmm.
Both short and long bolts are RSC on my 70. I am curious about the washer size too.
Go ahead and laugh, but I thought they should all have the star washer so I went and found one. Now I have no idea where the flat and lock washer could be.
Oh well
Bill
- Top
Hey Bill, been there, done that. I think many have done the same thing at one time or another. Gets worse with age I think.Michael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
