I have a 64 with drum brakes. During my frame off, I replaced every part of the brake system top to bottom including the PB booster, master cylinder, brake lines, blocks, wheel cylinders, brake shoes, springs etc. with correct "original style" parts. After reading many archives, I have decided to stick with GM/Delco Supreme II, dot 3. However, I am still a little unsure of the exact bleeding procedure. It seems that everyone has their own method.
Given the fact that the entire system is empty and has never had any fluid in it, what is the best procedure to fill the system (and keep it full) and bleed the brakes? I will be doing this manually with a helper. The master cylinder is already mounted in the car and I did not previously bench bleed it. The car is currently on car skates. I am assuming I will have to put it on jack stands and remove the wheels. I purchased an off set brake bleeding wrench and several feet of clear tubing. I also have four clear plastic gallon milk jugs that are super clean and dry.
Any thoughts would be appreciated. Since this is my first restoration, every step is a new learning experience for me.
Thanks in advance.
Tim
Thanks in advance.
Tim
Thanks again, Tim
