I wanted to take my car to the LI Metro meet Sunday, it was raining and, my wipers would not work.
I have power to the door/tray limit switch and it opens and closes as it should, also the same for the Knob switch under the dash at the steering column.
The triple wire terminal (1,2,3) plug in is of interest in solving this. The center, 2, is a yellow wire, 12v pos with ign on. Number one terminal is a Lt green wire to the dash wiper switch to provide GROUND. Third wire is the park guy to a relay.
I have power to the #1 terminal if the wiper tray limit switch is closed, and only then. I can see no way to have power there unless I have an internal short. As you know, the motor is not cheap, like me
, and I just want to be sure. Perhaps someone else has had this with a different solution? Next step is taking it out and bench testing I guess.
Thanks, Ken
1971 LS5
, and I just want to be sure. Perhaps someone else has had this with a different solution? Next step is taking it out and bench testing I guess.Thanks, Ken
1971 LS5
