Re: flooding holley carb on '67 300 hp
William,
To answer your questions:
(1) It was probably common in the 1970's to replace the 67 non-externally adjustable float fuel bowl with the earlier adjustable float bowls, once they started leaking at the pressed in caps on the top and side of the bowls. I know this was an early on problem with mine until I replaced the carb with a double pumper in 1976 and trashed my original 3810. Even in those days, a replacement 3810 was pretty expensive, around $500 to $600, and a generic carb was about half that.
(2) The build date(at least the week) of the carb is on the air horn as PT indicated, Year-Month-Week in 3 digits below the List #. If you have 4 digits it is a replacement after 1972.
(3) As far as I know, there were no 3810 production carbs with externally adjustable float bowls. But I could be wrong
William,
So it appears our engines were built a week apart. Maybe the 763 was indeed the last of the batch, as I've never seen anything later. PT
