Could someone tell me if the mark on the end of the worm gear should be at the 12 oclock position with the steering box centered ? Thanks,Graeme.
c3 steering box
Re: c3 steering box
Dukes Steering box paper can be found here. I read through just it this morning.
http://www.lbfun.com/warehouse/tech_...%20Rebuild.pdf- Top
Re: c3 steering box
Then try the Jim Shea page, http://jimshea.corvettefaq.com/?page_id=4
or wait for Jim Shea himself to answer the question.- Top
Re: c3 steering box
You didn't mention what year C3. All C3s (except 1968 and early 69) had a flat machined on the input shaft. That flat is always at 12 o'clock when the gear is right on center.
The early C3s had an input shaft that was full round (no flat). I didn't know that there was a mark on the end of the early shafts.
The way to determine the on center position for the early C3s is to rotate the gear full lock to full lock. Count the exact number of turns. (Should be 3.6.) Now go to full lock and come back exactly 1/2 the number of full turns. (Should be 1.8). You now have set the gear exactly on center.
Jim- Top
Re: c3 steering box
Chris- Top
