early 69 hose and wiring pictures - NCRS Discussion Boards
  • Michael B.
    • June 18, 2007
    • 400
    Re: early 69 hose and wiring pictures
    I'll have to double check but I beleive that line feeds vacuum to the heater controls on the console. If you are not aware, Astro Ventilation has a vacuum operated flapper under the rear window that opens when the heat is on cold and the vent dial is in the off position. The air flow it provides is subtle through the side dash and kick panel vents and you may not even notice it's not working. The vacuum servo is tucked up out of sight on the drives side.
    I think that hose connects to a "T" fitting in a larger hose in the engine compartment. Because of the size difference of the two hoses, an over the counter T-fitting is hard to come by. Corvette Central has this one #303303. It a
    • Kenny C.
      • March 2, 2009
      • 191
      Michael
      Thanks much, that makes sense. Funny thing is I have a hose routing diagram I got from Dr Rebuild and I don't see this shown. I would have thought it would show this. He actually has that Tee listed in his catalog for that application.
      I want to thank you all for your help and the time to post picture and diagrams, I really do appreciate it.
      Best Regards
      Kenny
