I replaced the timing chain, pulled the distributor and had it rebuilt now I am ready to put the distributor back in. My question is determining TDC.
I was told by a mechanic that if I put a piece of paper or tissue in #1 spark plug hole that when the motor is cranked around to TDC that it would blow the paper or tissue out. Well I did that and while it did not blow out the Newspaper piece I placed in the hole I did hear quite a bit of air escaping as the mark on the harmonic balancer came around to the timing tab.
Does this sound as though it is at TDC. I was going to manually spin the motor to 8 degrees advanced once at TDC.
Motor is in car with all plugs but #1 installed and the exhaust manifolds are not installed yet. Valve covers are in place too.
Thanks! Bill
Thanks! Bill
